Re: 12V Alternator Conversion Dead Short...?????
Posted by Janicholson on August 15, 2007 at 09:40:33 from (71.87.39.51):
In Reply to: 12V Alternator Conversion Dead Short...????? posted by Keith Stromberg on August 15, 2007 at 09:30:04:
SMOKE TEST
Pin #1 is the exciter current from the diode or resistor,or the idiot light, and from there from the ignition terminal (hot when turned on). If you used a digital meter, it might appear to have zero resistance, especially if set on high ohms range. I would put 12 volts to it as follows: use jumpers with the neg jumper to alternator frame, and positive jumper to a piece of wire with a spade connector on it to go to pin #1. apply porew and if no smoke, I would put it in the circuit. The only thing that could be dammaged is a diode, or resistor (as per the circuit Bob M provided. It is likely OK. JimN
