Often if a battery is like totally dead but not internally shorted n it has sufficient electrolyte, it can take a good while before she ever starts taking amps so leave it on high charge a while n see if she ever starts drawing current. Sure you can jump it buttttttttttt a totall dead battery may be like an amp suckin drain so you might (if it has a good charging system) be able to jump the STARTER ONLY n if she starts a good genny can supply the meager 4 amps required to power up the ignition.
Id take that battery to a shop for a good test n let them try n re charge it n load test it. If your charger is only a wimply lil trickle charge Im not sure if it will ever come to life. I set mine on a high charge rate n let them set n cook a while n finally once they (if ever) take amps i back it of for a good slow deep charge.
See if theres electrolyte above all the battery plates and that no cells have a different or gray milky color??? Give her more time on a charger,,,,,,,,,try n jump start (AT CORRECT POLARITY) ,,,,,,,,,,and/or try to just jump the starter n see if she will run????? Will it pull start?? (requires a good genny like Jim mentioned)
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
