Re: Ignition timing farmall cub
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by p on February 13, 2000 at 20:04:08 from (209.186.159.17):
In Reply to: Ignition timing farmall cub posted by Ed Epps on February 13, 2000 at 13:15:23:
As already posted make sure you are not actually on TDC #4, but also when working with the magneto, make sure that you line up the rotor after the magneto has snapped or else the timing will be way advanced. also are you using copper wires and do you have spark? also check points I had that on mine where they were so dirty that I got spark only sometimes....
Post A Followup
: Re: Re: Ignition timing farmall cub
