Re: Generator Adjustment
Posted by Janicholson on August 15, 2007 at 15:52:29 from (66.173.50.167):
In Reply to: Generator Adjustment posted by jeffalex2 on August 15, 2007 at 12:29:37:
If you have a regulator, the regulator gets the adjustment. If you have a 3 brush (older H) then the third brush is moved to increase voltage. Voltage regulator adjustment is pretty complex, and is best done with a book on the subject. this is "Delco A" type system with regulator grounding of the field coils. There are some posts from Me and others on the topic in the archives search for above. Good luck, JimN
