Re: 1964 IH 806 hydraulics
Posted by Weldon K on August 15, 2007 at 19:09:18 from (98.16.46.5):
In Reply to: 1964 IH 806 hydraulics posted by Ralph Kratz on August 15, 2007 at 10:42:37:
Did the PTO still turn ( operate properly) after hitting the rock ? If it stopped operating at the time of hitting the rock and will not operate now, the splines of the PTO drive gear which mesh into the splined hub on the clutch pressure plate have stripped due to being worn . The hydraulic lift and remote valves are supplied by a pump driven from the PTO drive shaft which is driven of the afore mentioned PTO drive gear. If the splines have stripped out, no PTO and hydraulic functions.
Repair requires tractor split, new PTO drive gear ( with new oil seals) and hub replacement on pressure plate. May as will do a full clutch job while you are there.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
