Re: 1066 front end parts
Posted by Brownie450 on August 17, 2007 at 05:20:38 from (207.177.82.144):
In Reply to: 1066 front end parts posted by Rickyp on August 16, 2007 at 19:41:48:
If you are talking about the 1" pin on the left side, We replaced it with a tapered stud with a locknut top & bottom. Our "independent" repairman got it for us---don't know if it was IH or some jobber had them. He had a taper drill bit to drill into the front axle just enough to form a seat for the tapered stud. Locknut top & bottom, & no more trouble. You might check with IH to see if they have something yet. The steering cylinder itself has 2 bushings--1 on top--1 on bottom--kind of pricey as I recall.
