Re: M Starter Switch
Posted by Bob Kerr on August 17, 2007 at 07:48:55 from (64.12.116.73):
In Reply to: M Starter Switch posted by Smokin Joe on August 17, 2007 at 07:30:48:
Too many amps going through it. pull the starter and take it to an auto parts store to test it. It may have shorted windings or armature. While your at it if you are running 6 volt, clean every single connection shiny bright.
