Left side of touch control, 4 bolts retain the screen, its rite below the fill plug at the bottom of the control. Best of luck try'n to git a new one to fit. the last new one i got from CNH did not fit so I put the old one back in. Some have temp a sender cable in the center, its part of the screen assy. mite as well tell ya were the pressure relief spring is, remove the battery then the head on the touch control, the spring is in the center B-low the lift cylinders/center. You can C this one is broke, this one worked but did not like to B loaded.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
