Posted by Janicholson on August 17, 2007 at 09:26:53 from (71.87.39.51):
In Reply to: M Starter Switch posted by Smokin Joe on August 17, 2007 at 07:30:48:
I agree with Bob below, THere is one other possibility. If your switch is the type that covers a copper stud on the side of the starter, and that stud gets worn down from use, a new switch will not last long befor it is out of motion range. The copper can be built back up to about 1/16" more material whewe it hits by sandwiching a piece of copper to the terminal and silver soldering it on. It usually requires the stud to be removed from the housing to avoid heating the insulator and ruining it. It can also be brazewelded back to height. JimN
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
