Re: H-carb default(base setting) please help
Posted by Janicholson on August 17, 2007 at 09:30:39 from (71.87.39.51):
In Reply to: H-carb default(base setting) please help posted by BIG RED 1 on August 17, 2007 at 06:55:09:
# to four is more like it, but if it is as described, the float level might be set too high or sticking. The load control screw adjusts the high speed circuit within a small range, it is not the main jet. The tractor should run much better than it is befor that screw will be effective in taming the trim adjustment to make good power. JimN
