Re: Knocking sleeves in
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by The Red on February 14, 2000 at 08:12:50 from (206.246.187.2):
In Reply to: Knocking sleeves in posted by Bill on February 14, 2000 at 07:06:08:
Bill, all I did was shine up the cylinder walls with steel wool and coated it and the outer sleeve walls with WD 40. I kept the sleeves in the freezer for 2 days. They pushed down about 2/3 of the way then I used a block of oak and lightly tapped them all the way in. I had no problems whatsoever.
Post A Followup
: Re: Re: Knocking sleeves in
