Posted by John T on August 17, 2007 at 10:47:41 from (66.244.83.147):
In Reply to: M Starter Switch posted by Smokin Joe on August 17, 2007 at 07:30:48:
If that starter stud/post under the switch is burned n pitted you might get by with a light filing to clean n smooth it up but I agree it sounds like it may need replaced soon or else try n build it back up like Jim was talking about. As always I advise you ro remove, clean n wire brush n reattach each n every battery n starter n ground cable attachment, use 00 gauge cables on 6 volts or 0 or 1 on 12 volts and use a heavy duty battery. It might be time for a shop to check the starter for excess amps maybe from worn bushings or perhaps it needs some brush or commutator work.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
