The A casting date code would indicate you have a Farmall 100. Which casting had these two codes? The engine serial number is directly below number one spark plug on a machined flat surface and the numbers and letters are stamped in place as opposed to cast in place. That machined surface will contain tractor model number and engine serial number.
Super As after serial number 310300 started to have a spread between tractor and engine, engine number always higher. By the end of production in 54 that spread was about 2000. For example my Super A has tractor serial number 336977 and engine serial number 338597, 1953.
If you have a 100, a new set of guidelines kick in, Farmalls 100 and 200 each had a separate set of tractor serial numbers, however the engines shared the same sequence of numbers. Those soon got way off from being the same.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
