Posted by Janicholson on August 18, 2007 at 16:43:47 from (66.173.50.68):
In Reply to: Wiring questions posted by Butch WI on August 18, 2007 at 14:02:07:
I do not know whether the gauge needs a instrument voltage regulator, (the caseih.com parts description will tell. either way make a series circuit from neg to gauge from gauge to sending unit, and sending unit to pos. (assumes pos ground) when connecting the last wire, just tap it on the terminal. The tapping is to allow the possibility that something is horribly wrong. if the gauge seems to not respont to the touching of the wire to the terminal, connect it and then move the float to see if the needle follows the float. Do not expect rapid needle movement, they do not need to be sensitive. good luck, JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
