Re: Loose balls in the gear box
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by big fred on February 14, 2000 at 10:30:42 from (199.238.169.46):
In Reply to: Loose balls in the gear box posted by Bob G on February 14, 2000 at 08:54:47:
Good luck, when I took the PTO off my B, I noticed a little wedge shaped piece of metal. Turned out there was a whole mess of 'em. It was the teeth off the oiler gear, every dang one of 'em was sheared off. Should have been 39 of them, I only found about 20.
Post A Followup
: Re: Re: Loose balls in the gear box
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
