Re: Tricks for siphoning gas?
Posted by HENRY E NC on August 19, 2007 at 14:34:23 from (216.119.6.121):
In Reply to: Re: Tricks for siphoning gas? posted by the Unforgiven on August 19, 2007 at 12:57:45:
Janicolson has the best method. just make sure the end is below the tank at all times. I usally put a wire on the corked end and and several lead fishing weights on the open end and dip the whole tube in the gasoline and then pull the corked end out and quickly get it below the tank and open it up. A little patience will make it work.
