Re: Tricks for siphoning gas?
Posted by Delta Bob on August 19, 2007 at 18:00:21 from (64.89.163.72):
In Reply to: Tricks for siphoning gas? posted by Mike CA on August 19, 2007 at 12:35:18:
Use a clear 5/8 or 3/4 inch hose and use your thumb as a check valve.With the hose at the bottom of the tank,put your thumb over the end of the hose and pull up about a foot,then release your thumb and push the hose down to the bottom of the tank(fast).Repeat until the hose is almost full, then drain into a container.
