Re: Help! H is stalling uphill or when turning right?
Posted by forterox on August 20, 2007 at 11:25:30 from (75.192.133.107):
In Reply to: Re: Help! H is stalling uphill or when turning right? posted by K-Mo on August 20, 2007 at 09:22:46:
Still does it with 5 gal in there. I've had the bowl off/cleaned but didn't get up inside the stand pipe, figured if it's pouring out of the line at the carb I'm okay, but noticed the float valve (carb apart) only let a trickle through when open, it's clean, is that normal? Seems like the "turning left" thing is simply pushing what gas is left in the resevoir over into the intake hole. The whole thing is clean. Hey, thanks for responding so quick. Scotty
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
