Re: Help! H is stalling uphill or when turning right?
Posted by Janicholson on August 20, 2007 at 13:28:10 from (199.17.6.122):
In Reply to: Help! H is stalling uphill or when turning right? posted by forterox on August 20, 2007 at 09:11:26:
I like George's answer. if you have strong power on the flat, cornering or up hill should make little difference. There is a screen in the fittong at the carb inlet that is often guilty of restricting flow. Setting the float level to spec and checking the screen, is a good idea. Electrical issues may be the problem. While it is running and brakes locked, wiggle wires and looms from the coil on bact to the elect box, and to the battery. JimN
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
