Posted by Greg Lasher on August 20, 2007 at 13:36:35 from (68.46.61.156):
I just got an 0-12 and the clutch is stuck. Can you access the clutch under the steering box, and is there a coupling like a bulldozer that can be removed or do you have to split the tractor? My second question is, no matter where I place the mag advance/retard lever it seems like it is impulsing at the same place. The piece on the mag is turning but the mag never goes off like it should. I marked the crankshaft and the pulley to see which was advance/retard and it keeps impusing at the same place -- any ideas on what is wrong? The part that rotates on the mag is "indexed" with the two little teeth - I know it is just not turning on the body of the mag. After I get it working which way is advanced? If I take the mag off I see there are 4 bolts that hold the mag on and two in the coupling -- does the couping have to be marked or can it only go on two ways?
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
