Re: Are Chinese radiators any good?
Posted by gene bender on August 20, 2007 at 18:00:09 from (67.55.226.214):
In Reply to: Are Chinese radiators any good? posted by liveoak415 on August 20, 2007 at 15:07:09:
You will be much better off going to a salvage yd and getting a good used one. Are you sure you even need a new one as lots of the old engines have crud in the block and then have bad cooling problems.
