Re: Farmall 806- torque converter/amplifier or compression p
Posted by chuck46 on August 20, 2007 at 21:52:47 from (64.136.27.229):
In Reply to: Farmall 806- torque converter/amplifier or compression probl posted by Placer on August 20, 2007 at 19:40:22:
Hi, It may not be a bad TA, if it freewheels with the TA back check if the transmission oil light is on. I think on an 806 it is combined with the engine oil light, if it stays on the dump valve is hanging up. They are cheap to clean or replace and if you are lucky the TA may still be good. Good luck, Chuck
