Re: Locked up H
Posted by old on August 21, 2007 at 07:11:58 from (4.245.4.56):
In Reply to: Locked up H posted by Markpa13 on August 21, 2007 at 06:54:55:
I would first start by pulling the starter off and make sure it didn't lock up on the flywheel, common problem with the farmall tractors and it could be just that simple. As far as it just dieing it could be that you do have a weak battery and weak battery means weak spark unless if has a mag on it
