Re: Farmall 806- torque converter/amplifier or compression p
Posted by dwag on August 21, 2007 at 10:36:32 from (74.40.170.74):
In Reply to: Farmall 806- torque converter/amplifier or compression probl posted by Placer on August 20, 2007 at 19:40:22:
Check DD and TA press's., feeder tube o-rings. I had a 706 "freewheel" after installing a new TA, "went through" the MC Valve and fixed the problem. Don't know what was wrong, but tractor is still running after 20+ years. Worth looking into before "slapping in" a TA.
