Re: CUB AXLE SEALS
Posted by Brian Schmidt on August 21, 2007 at 10:43:46 from (12.207.191.152):
In Reply to: CUB AXLE SEALS posted by BILL DORRANCE on August 21, 2007 at 07:06:17:
The outer seals that are usually leaking must be accessed by removing the housing, tearing it down, and pressing the axle off the bearing. It is not as hard as it sounds. I done mine in a couple hours. Make sure when you press it out to keep the spacers in line so you get the correct spacing on the gear and correct preload on the bearings.
I would buy the cap and seal from IH. The inner seal of the seal retainer is replaceable, but them seem to be deformed over time and the new seals won"t fit.
Good Luck.....
