Re: Farmall 806- torque converter/amplifier or compression p
Posted by Kevin Meier on August 21, 2007 at 14:06:54 from (64.71.85.247):
In Reply to: Re: Farmall 806- torque converter/amplifier or compression p posted by Placer on August 20, 2007 at 20:30:46:
You don"t want to replace just the clutch pack parts on a t/a that is worn out. If that"s what"s wrong. Usually when a t/a goes bad it"s got worn sprag. The sprag is what keeps the tractor from freewheeling down hill works kinda like a brake on a bicycle. There are also 3 seal rings that ride in a bushing 1 for t/a 1 to split the t/a from the direct drive and 1 seal ring for direct drive. When they wear out they usually wear the ring glands on the shaft also. Which means if the t/a is bad replace the entire t/a not just pieces. If you have any questions feel free to email me about replacement parts or rebuilds.
