Re: need engine for IH 300/350
Posted by puller1 on August 22, 2007 at 05:04:02 from (71.171.11.12):
In Reply to: need engine for IH 300/350 posted by puller1 on August 21, 2007 at 18:09:08:
I was looking for a complete engine for a quick swap,A crank out of any H or 300 or 350 will interchange all you have to do is use the main bearings for the crank you are using the bearings have a different I.D. but the same O.D. thanks
