Re: Converting a 450 LP to Gas
Posted by NDS on August 22, 2007 at 13:39:24 from (205.188.116.73):
In Reply to: Converting a 450 LP to Gas posted by Albert Pereira on August 22, 2007 at 12:50:27:
I have converted M back to gasoline and essentially all I did is remove LP equipment and put on gasoline tank lines and carburator the maniflods are different and probaly should be changed but it runs OK with LP manifold. If 450 is factory LP compression may be high enough to require premium fuel. The thing that convinced most to go to LP back in fiftys and sixtys was that fuel was a lot cheaper but that is not so today. Engine in LP tractor will usually run a lot longer than gasoline tractor too.
