the cub has the c-60 motor in it. it does not run sleeves. also, the valves are in the block, not the head. the reason the trans fluid came out the carb is because one of the intake valves are open. lot of guys here use trans fluid and have good luck with it, others have their special home brews. use whatever works.how long has the tractor been sitting since it ran last? if you bought it stuck, i would pull the cylinder head and oil pan and see whats up in there. the super m i am woking on now sat for close to 20 years in a barn, stuck good. as i am overhauling it anyway, first thing i did was drain the engine oil, and fill the block with kerosene and let it set for a month. drained it out, filled the cylinders with pb blaster, let it set a couple weeks. between rocking the tractor by hand in 5th gear and bumping the starter, it broke loose. then it was a lot easier to disassemble. its your call how you want to proceed, if you break it loose, it may run good. my luck it would toss a rod out the side of the block first time it fired up.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
