Re: Cub Stuck----- correct procedure
Posted by old on August 22, 2007 at 19:26:58 from (4.245.1.100):
In Reply to: Cub Stuck----- correct procedure posted by Mifsud on August 22, 2007 at 18:46:49:
Guess what your doing it the right way. Most likely the cylinder with and open valve still has enough tranny fluid sitting on top of it to do the job it needs to do. If your worried about it then just take a hose clamp and some thing and cover the carb up and fill the cylinders more since the ATF will not hurt the carb any shoot it will probably help it in the long run
