Re: Cub Stuck----- correct procedure
Posted by the tractor vet on August 22, 2007 at 21:53:25 from (75.19.123.112):
In Reply to: Cub Stuck----- correct procedure posted by Mifsud on August 22, 2007 at 18:46:49:
Now if it was me i would just have to pull the head and see why it is stuck as it being a cubby with a flat head and for the price of a head gskt. I wouldnot waiste my time tryen all the old wifestail methiods . I have said this before and i will say it again best stuff i have found bar none is Zep's penatrating fluid hard to find but worth the hunt. Pop that head off get some Zep a littel spray here and a littel tap there will solve the problem if it is not total rust like the one cub i ended up withthat the man said was only lightly stuck , yea wright could not tell were the pistons ended and the bore started . That one went to the dead row may have ended up being a Toyota .
