Posted by Marty K on August 23, 2007 at 10:14:21 from (128.251.109.118):
In Reply to: 450 T/A rearend lube posted by Chester5731 on August 23, 2007 at 05:38:47:
The T/A chamber is separate from the transmission. My 450 doesn't have a T/A but there was some oil in the bottom of the T/A chamber when I tore it open during restoration. There were two standpipes about 2" long that maintained an oil level on each side of the PTO shaft passageway but I don't think that would apply to a tractor with a T/A. Yours may have actual drain plugs positioned side by side on the bottom of the tractor. One is a 1/4" pipe plug and the other is 3/8" pipe plug. These would be in line with the 3/8" T/A oil level plug on the left side of the case about in line with the clutch pedal pushrod. My standpipes were only accessible by removing the top cover on the clutch housing behind the clutch bell. It looks like it would hold about 2 gallons.
As far as the transmission, I've got mine nearly torn down to the transmission case casting, but I understand it holds about 15 gallons of oil. Some of this oil moves all the way forward in a separate passageway to the PTO reduction gears right behind the clutch.
I've heavily documented my restoration with pictures so if you send me an email, I can send you some. Hope I've answered more questions than I've created. Bob (MartyK)
Today's Featured Article - Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
