Re: Farmall A Magneto/Battery Ignition?
Posted by CNKS on August 23, 2007 at 18:45:02 from (216.144.103.153):
In Reply to: Re: Farmall A Magneto/Battery Ignition? posted by scotty on August 23, 2007 at 04:35:45:
I'm not sure when the distributer became "standard", but when it did the mag was still optional for a period of time, yours may or may not have been ordered that way. I have no preference. My 1948 C has a distributer, likely a replacment.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
