Re: Converting a 450 LP to Gas
Posted by John A. on August 23, 2007 at 20:39:56 from (4.253.43.91):
In Reply to: Re: Converting a 450 LP to Gas posted by Albert Pereira on August 23, 2007 at 10:35:14:
Albert, 10:25 Thur nite,......Your engine is a running engine So a basic overhaul is needed. you may be able to get by by with just running a Ball hone in the cylinder and reringing the pistons. But you have the engine at least to the point where, if you do not chech everything out you will probably be back in the engine to fix something else.
Put a mic to the mains and check to see what it measures. Are the areas where the main bearins are, are they round, egg shaped or just what.
LPs useally do not have much wear, so there is a good chance that the bottom of the engine is OK. you may very well have a broken ring or two. OR it could be on the verge of really shelling out on you and really cost you a ton of $$$$ to fix.
Call me, my Cell # is 512-577-3837. I can better visit about this than type-talk. Look forward to visiting about your 450.
Later,
John A.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
