Re: back blade edge question......opinion needed
Posted by Janicholson on August 24, 2007 at 09:25:44 from (66.173.50.97):
In Reply to: back blade edge question......opinion needed posted by tfringo on August 24, 2007 at 08:36:32:
If you are doing a gravel drive that is 150' long twice a year, I would use mild steel stock 3/8"X3" if I was going to use it professionally, or quite often I would find a discarded county grader blade to use. They are made from high manganese steel and resist abrasion and are just for that purpose. Why used, is that when they get done with them they are just about the perfect dimensions for a back blade. Do not sharpen it like a mower blade, it should be beveled so that when it is on flat concrete attached to the tractor the front edge is touching and the back edge is about 1/8" in the air. this allows maximum support for the edge while allowing it to "hook" into the soil/gravel you are moving. JimN
