Re: touch control O/H kit from Case/IH-Comments?
Posted by Hobo,NC on August 24, 2007 at 19:47:26 from (151.213.83.58):
In Reply to: touch control O/H kit from Case/IH-Comments? posted by BIG RED 1 on August 24, 2007 at 08:22:55:
third party image
I have done 1, I lay the parts out then when I reassemble I pick it up, remove the o-rings and lay them out then match them up to the new ones. then spray the part with brake clean, lube and install. The manual has a great pix of the parts. I did not get all of the pressure relief valve parts out, but did find them in the bottom part in my clean'n tank after I installed the unit and it would not lift till I had max RPM.
If I were to do another one i would clean the case spick and span B-4 I took it apart. Then i could spray off the case on the table and reassemble. I would get a new pressure relief spring. far as the boots you can make'em your self or pay big bucks for CNH junk, what a rip off. I did git a new straniere it did not fit up flush with the case, I returned it and got my $68.00 back for it. @ that price I was not going to do a shim and fit. Instructions will come with the o-ring kit, believe them. Their is something about not pushing the control rods all the way in it will cut the o-rings I can see were it would. Its a PITA to git the lift linkage loose from the lift pistons/control rods, take plenty of pix'izz of the linkage. I have another and had to go take a peak a few times.
