Re: LP M isn't getting gas
Posted by Nebraska Cowman on August 25, 2007 at 05:40:47 from (65.165.16.91):
In Reply to: LP M isn't getting gas posted by bnowen on August 24, 2007 at 19:42:36:
NO, LP don't get gunky like gasoline does. There is a suction hose from the carb to the pressure regulator that tells it to turn on and send vapor. Hard to tell what is wrong but if tractor has been sitting the valve could be stuck. I assume you have the valves turned on at the tank? Yeah, both liquid and vapor. I think the rule in the old days was start on vapor and run on liquid but I leave both vales open. Once you start turning them off and on they go to leaking.
