Re: Tell me I don't have to split it!
Posted by Patrick Martin on August 25, 2007 at 20:27:07 from (64.154.26.250):
In Reply to: Tell me I don't have to split it! posted by cole on August 25, 2007 at 19:54:58:
Depends on how worn down you mean. If just a little then yes it's possible.
Remove the flywheel inspection cover (behind the oil pan) and you ought to be able to get a file in there. You can also get it through the starter hole once you remove the starter.
