Re: hydraulic system check
Posted by Patrick Martin on August 25, 2007 at 20:47:37 from (64.154.26.250):
In Reply to: hydraulic system check posted by Pat-CT on August 25, 2007 at 19:53:47:
Yeah you should have a dip stick attached to the cap.
I think you can screw a test gauge into the line and check to see if the pressure output is what it's supposed to be but aside from that I don't think there is much else you can do.
The I&T manual shows a special gauge used for this but you can use a regular pressure gauge and steel line with a threaded end to fit the port or line. I think you will probably need a 2,000-3,000psi gauge for this. I used a 2,500psi on my 100.
