Re: hydraulic system check
Posted by Patrick Martin on August 25, 2007 at 21:02:00 from (64.154.26.250):
In Reply to: hydraulic system check posted by Pat-CT on August 25, 2007 at 19:53:47:
By the way, you might want to put a T in the output line. If you do this you can tap into this line and run a steel tube up to the light bar and install a gauge. Now you will have a means of monitoring the hydraulic system pressure in case an internal leak develops. This way you can stay on top of things going on inside your tractor! :)
