Re: Fellows.......I gotta prob with the 400
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Brian Schmidt on February 14, 2000 at 22:33:14 from (216.178.176.145):
In Reply to: Fellows.......I gotta prob with the 400 posted by Richie on February 14, 2000 at 21:39:41:
Not a rocket science answer, but you are over fueling. Check the carb for a leaky seat, too high float level, or just try to lean out the carb a little. What range and type spark plugs are you running. Try a little hotter spark and stay away from Champion plugs. Use AC or Autolites.
Sounds like the guy knew there was a problem, thats why he had to clean the plugs that day. It sounds like you need a carb kit most likley.
You are in luck though, IH carbs are easy enough for a 1st grader to rebuild. Give that a shot. TSC has kits for around $5-$20 depending on model.
Hope this is of some help.
Brian
Post A Followup
: Re: Re: Fellows.......I gotta prob with the 400
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
