Re: 460 diesel going nowhere
Posted by D Slater on August 26, 2007 at 03:39:08 from (71.164.50.24):
In Reply to: 460 diesel going nowhere posted by pondman on August 25, 2007 at 18:42:23:
The main clutch or the T/A clutch is slipping and if its the T/A clutch your T/A is out on the low side. Only way a adjustment will help is if there's no free play between releace bearing and clutch plate fingers of either clutch and the fingers are held partly down. Fixing whichever clutch is slipping will make it pull in high T/A, but if the main clutch is not the problem (main clutch holds but tractor still stops when handle is pulled back) the T/A needs repair for low side to pull.
