Re: Here We Go Again, Mike
Posted by Allan In NE on August 26, 2007 at 08:30:45 from (148.78.243.24):
In Reply to: Re: Here We Go Again, Mike posted by the Unforgiven on August 25, 2007 at 20:05:11:
I would guess, since the tractor is located out in Idaho, the little guy was used to push a bean cutter and that part mounted the center row divider.
I've used "clamp around" 1/2 x 1 1/2" steel for the same purpose.
Allan
