Posted by Janicholson on August 26, 2007 at 09:06:36 from (66.173.50.21):
In Reply to: Re: Radiator removal posted by Patrick Martin on August 25, 2007 at 22:11:20:
I must respectfully disagree. I think I would stay in the area of 10 PSI or less the flat structures of tanks were thick enough (on the pressure cap radiators for 7PSI caps, but 30 is begging for flexing the metal and making grief.. Risky at best. JimN
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
