Re: difference bd144, bd154 engines
Posted by Fromjb2 on August 26, 2007 at 11:51:15 from (74.111.67.38):
In Reply to: difference bd144, bd154 engines posted by eddie9 on August 26, 2007 at 11:21:47:
Hi Eddie, from the CNH parts web site:
http://www.caseih.com/parts/parts.aspx?navid=123&RL=ENNA
Unfortunately B250 is not listed but B275, BD144 and B414 are, so see below for part numbers and serial number ranges.
Is it possible that the shaft is shorter on B250 because it did not have an hour/tachometer on the dash? Hour meter was by injection pump. I know on B275 & B414 Diesels the hour/tachometer ran from an assembly that attached to the top of the oil pump drive shaft.
BD144 Engine:
3043131R93 PUMP PUMP ASSY., oil, Engine serial no. 17289 and above.
B275D-BD144:
3043131R91 PUMP, ENGINE OIL PUMP, oil assy., BD-144/17289A up.
B414D-BD154:
Before serial 30944:
3043131R93 Pump Pump Assy, Oil, Bsn BD-154/30944
After serial 30945:
3064060R91 Pump Pump Assy, Oil, Asn BD-154/30945
JimB
