Re: Fellows.......I gotta prob with the 400
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Phil Auten on February 15, 2000 at 06:10:13 from (206.175.72.226):
In Reply to: Fellows.......I gotta prob with the 400 posted by Richie on February 14, 2000 at 21:39:41:
Richie,
Brian is right. Too much fuel is being fed to the engine and the plugs are fouling with soot. Start by adjusting the idle mixture screw for best idle when warm (if that's possible where you are). After the engine gets up to operating temp, adjust the other screw for best operation under load. This will take some time with adjusting and trying it out unless you can do it with some stationary PTO work. I would also replace the plugs. I am running Champion D21Y plugs in my M and have no problems. I had fouling with D15Y and D17Y plugs though. I haven't tried Autolite or AC plugs yet, but others on this and other lists swear by them.
Phil
Post A Followup
: Re: Re: Fellows.......I gotta prob with the 400
