Re: IH Super C
Posted by georgeky on August 26, 2007 at 18:41:54 from (64.12.116.73):
In Reply to: IH Super C posted by Jack Sprangel on August 26, 2007 at 17:29:32:
I have heard lots of folks run down Carter carbs. I have used them for years and had no problems that don't happen to other carbs as well. I would do as Jim says and check the fuel flow and then try another coil. My SC would run perfect until you dropped the plow and the it missed and sputtered and had no power. It was the coil. A new one fixed it right up.
