Re: Putting a tachometer on Farmall MD HOW TO?
Posted by Bob M on August 26, 2007 at 19:39:15 from (69.205.124.61):
In Reply to: Putting a tachometer on Farmall MD HOW TO? posted by Brad in WI on August 26, 2007 at 17:37:02:
Brad - If you can find one, a tach and drive assembly from a later model Farmall with the "start on gas" diesel (eg. 450D or W450) could be adapted.
If you are clever with electronics you could take an electronic car tach and use the breaker points inside the MD mag or distributor for the RPM signal. This would require a bit of engineering however - it would not be a simple "attach the signal wire here" hookup.
Or if you MD has had the generator replaced with an alternator, a "universal diesel electronic tach" would be easy to install. Isspro, Datcon and others make 'em....
