Re: Farmall 450 LP Coil
Posted by Janicholson on August 26, 2007 at 21:30:59 from (66.173.50.175):
In Reply to: Re: Farmall 450 LP Coil posted by teddy52food on August 26, 2007 at 18:10:54:
Though it seems wrong to have idle volts higher than load volts, I have extensive operating (and training) on a sun scope attached to everything from a lawnmower, to a 57 Mercedes 300SL coupe. With the scope, one looks at the actual spark line and it is scaled in thousands of volts on the screen.
Idle voltage is always higher than load voltage. for the reason I stated. JimN
