Think you might have a 3142 backhoe.They would be at least 30 years old. Is there a ound jug on each side of the swing taht is held in place with a bunch of bolts.If this is what you have it"s not to hard to fix. Remove boom assy. from swing. remove big nut at bottom of swing shaft. Get all hoses ouyt of the way. Mark and remove each jug. Make sure you know exactly how they go back on. Remove the two top bolts that hold the top spline bracket on the frame. Then lift swing off of main frame. The shaft has to be pressed outfrom the bottom. There is a big allen screw holding the big bushing in the top of the swing housing screw MUST be removed before pressing shaft out. Will try to find parts break down for you. If you want me to email me
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
